Which Component is the limiting factor?
I did a lot of reading I am am successfully receiving data from the instron in block format.  I even was able to remove the header, typcast, split the 2D array, and plot the data.
 The only problem I am having now is that the block data from the instron is in little-endian format and the type cast function expects big endian format.  Is there a simple solution for this?
Message 11 of 15
(844 Views)
"Swap Bytes" VI.  Is this what you are after?
Bill
Bill
CLD
(Mid-Level minion.)
Message 12 of 15
(836 Views)
Bill:
Thanks for tip.  I think swap bytes will work great for uint16 but I am using uint32.
I think I will try array destructor and combine bytes.
Message 13 of 15
(827 Views)
There's also "swap words."  🙂
Bill
CLD
(Mid-Level minion.)
Message 14 of 15
(825 Views)
After fighting with the Instron syntax I finally got the data logger to work and I also got labview to process binary blocks of data.  Thanks to every who helped.
Message 15 of 15
(792 Views)
