11-14-2012 03:59 AM
I am new in Labview programing and i plan to capture AC Voltagel(Not DC voltage).
I have DAQ 6009 card.
My question is DAQ 6009 support Capture AC voltage? otherwise which DAQ card support to capture AC voltage
11-14-2012
05:49 AM
- last edited on
03-17-2025
04:07 PM
by
Content Cleaner
The question is what is AC for you? If you are talking about this system https://www.ni.com/en-us/support/model.usb-6009.html you have a maximum sample rate of 48 kHz, so according to the Nyquist criterion you can sample up to 24 kHz. Is that AC enough?
Cheers
Edgar
11-14-2012
05:51 AM
- last edited on
03-17-2025
04:07 PM
by
Content Cleaner
Hi CPUT
You can find the detailed specifications of the 6009 here. You can measure an AC voltage between ±10 V of GND using this module.
Kind Regards
11-14-2012 06:41 AM
An AC signal is nothing more than a constantly changing DC voltage. Ok, there's more to it than that. But still, the DAQ takes quick snapshots of what the signal voltage is at a given instant. If you take enough of these snapshots, you can recreate the signal. Niquist states that you need to sample at at least twice the bandwidth of your AC signal. I recommend more of 3-5 times.
