Blodeddates in .net Month calendar does not appear
I need to show a .net month calendar with some dates in bolded in this sense, there are some methods to do that and I have chosen "Boldeddates" (see image #1). The problem is that in the .net window calendar does not appear the bolded dates selected and sometimes the .net window turns to white when I run the program. I attach a image of my program. I work with LV 8.6, windows XP and .net framework 2.0.
(2,699 Views)
Accepted by topic author Islero
Ok, I have solved my problem with a little trick in order to deceive my windows XP. The trick is refresh the .net calendar advancing one month and right after it returning. Yes, it is really amazing but, is it not windows amazing by itself?
I have attached my VI in LV 8.6. The VI has been tested with success in:
* LV 8.6, windows XP and .net framework 2.0.
* Windows 7, .NET 3.5 y LabVIEW 2010.
Special thanks to NI Spain for their help.
Regards
(2,697 Views)
HI!
I had the same problem, but only while runtime.
After changing my code like you did it works! Kudo!
(2,580 Views)
