Which Labview suite for operating Lock-in amplifier
Hi All !
  I have to purchase Labview software only for communicating and data acquisition from Lock-in amplifier. Could you please suggest me which suite of the Labview is just sufficient to do this work viz. Base, Full or Professional Development system.
Thank you
(4,168 Views)
What lock-in amplifier? For communication to a GPIB/USB/Ethernet instrument, the base version is sufficient but I would recommend at least the full version if you plan to do any sort of analysis of the data you acquire.
(4,156 Views)
 One more thing, can you provide some program to read lock-in from Labview.
(4,117 Views)
Why do you continue to post without the details I asked for? Don't you know the male and model of the instrument? That's essential information if you want an example.
(4,094 Views)
SR830.  I didnt get your question in your first reply.
(4,089 Views)
Use Help> Find Instrument Drivers. This will install a LabVIEW driver in the correct location. You can then open the example finder (Help> Find Examples) and look under Hardware Input and Output. Look at the main driver page for instructions on how to use a driver.
http://www.ni.com/downloads/instrument-drivers/
(4,082 Views)
Ok. Thanks
(4,074 Views)
