Which driver is required to interface LabVIEW 2012 with NI cRio 9025
Dear Sir
I am trying to interface the LabVIEW 2012 with NI cRio 9025. But I did not see the device in MAX then I read through the internet that I need to install NI RIO driver. Can you please guide me from where I can get this driver?
The installed Labview toolkits as appeared in Function Block is attached.
Thank You
Kind Regards
Muhammad Irfan
Message 1 of 13
(4,473 Views)
Hi Irfan,
Then why don't you show a screenshot of MAX?
An image of the device is irrelevant here…
From your installation package. As you need LabVIEW-Realtime (and maybe LabVIEW-FPGA) modules you should have get all the needed DVDs…
This is irrelevant.
Please post a screenshot of MAX with the "Software" tree expanded!
- How did you connect your PC and the cRIO? Is there a switch or router involved? Are both devices in the same IP subnet?
- Did you follow the installation description in the user manual of the cRIO9025?
Message 2 of 13
(4,464 Views)
Dear Sir
1. The screenshot of the MAX has been attached.
2. We connected the CRIO 9025 with Laptop through ethernet cable. The IP settings were made according to the instruction manual given in our lab (screen short attached)
3. The LabVIEW installed on my laptop has the real-time and FPGA toolkit installed. You can see in the previous screenshot.
Message 3 of 13
(4,452 Views)
Hi tronoh,
I asked specifically for a screenshot with "Software tree expanded". Please try again!
I'm used to configure the very same IP subnet on my computer and the cRIO instead of using 10.10.10.x on the computer and 169.254.125.x for cRIO. But I'm no expert in IP subnet configuration, so when your instructor tells you to do so you need to do so (and ask him/her about IP configuration)!
No, I can't. You have those palettes not expanded nor did you attach the MAX screenshot as I requested (see point 1)…
Message 4 of 13
(4,447 Views)
I have connected the cRION 9025 with PXIe-1082. I can see the  cRION 9025 icon appear under the remote system. Attached is the screenshot.
Can you please confirm whether the device IP is correctly configured? And what is the further process to measure data of accelerometer connected with slot 1 of cRio9025, NI9234 module.
Should I use DAQ assistant to acquire data?
Message 5 of 13
(4,443 Views)
Hi tronoh,
Well, atleast you can see the cRIO now with MAX.
I still prefer to use the very same subnet for PC host and cRIO… (Ask your network admin!)
Now you start programming the cRIO!
(LabVIEW comes with ready-to-use example projects explaining the basic steps of communication between PC host and cRIO target.)
No, DAQmx does not work with cRIO devices.
(Well, now there are brand-new devices which offer that, but your cRIO is a little bit older…)
Message 6 of 13
(4,437 Views)
Dear Mr. GerdW
Our objective is to measure the vibration using an accelerometer. We want to display vibration data on a graph and want to calculate time domain parameters. We have following NI modules:
NI 9234 (Attached photo)
LabVIEW 2012
1. We do not want to use compactRio (due to the problem in the interface).
2. Is it possible that we buy NI USB 9162 module and connect it to NI 9234 module.
3. Then the USB connection with the Laptop and then measure the vibration using DAQ Assistant.
What is your advise about this? Will it work? Do we need any other interface or driver?
I shall be thankful to you for your attention and consideration.
Message 7 of 13
(4,417 Views)
Hi tronoh,
Which "problem in the interface"? I'm always happy to work with cRIO devices…
Sure. The manual even explicitely mentions this option!
3. Then the USB connection with the Laptop and then measure the vibration using DAQ Assistant. What is your advise about this? Will it work? Do we need any other interface or driver?
It will work. You don't neet a different "interface"…
My advise: get rid of DAQAssistent and use "plain" DAQmx functions. They are really easy to use and LabVIEW comes with a huge library of example VIs…
Message 8 of 13
(4,410 Views)
Thank you for your advice.
1. How much will be the cost of NI USB 9162?
2. Can we interface accelerometer (which has BNC connector) with PCI card (SCB68 connection terminal)?
Message 9 of 13
(4,408 Views)
Hi tronoh,
1. Call your local NI sales rep! (Or check NI's website…)
2. Which "PCI card" are you talking about? Surely you can connect an accelerometer to a SCB68 connector box - the important part is the DAQ hardware you use "behind" that SCB68…
Message 10 of 13
(4,405 Views)
