Which index values can be sent to "Insert Into Array" without changing the present array ? E.g. index -1 ?
Could not find this info via the "Context Help" window.
(2,636 Views)
In Array Palet you have "Replace Array Subset".
Try it.
(2,636 Views)
If you have to handle situations where you do not want to insert something in an array, then you can either use a negative index value as you suggested, or put the insert node in a case structure, with the "do not insert" case empty (almost...just crossed by the array wire!..)
Chilly Charly    (aka CC)
(2,636 Views)
Sounds like a couple of good suggestions! Thanks, Erik
(2,636 Views)
