hex input string to boolean array conversion
I have a 4 channel DI mod, and I am trying to convert the read hex value (0000-000F) to an array of individual boolean values or bits. how can I do this?
thanks
John Davis
(6,118 Views)
Hello jd4moto,
if your hex value comes as number you can use the "number to bit array" conversion (math palette-> conversions). If it is a string you should use the "Scan from string" with format set to hex string and do the conversion to bit array as above.
(6,118 Views)
