Which version of NI vision module is compatible with IMAQ 2.5.1
I have labview 7.1 for data acquistion. I wanted to control some of the Kodak Megalplus ES 1.0 cameras via PCI IMAQ 1422 card through labview. The motion is vision module is not in the Labview that I have. Which version of the vision acquistion module is compatible with Labview 7.1/ IMAQ driver version 2.5.1. Where can I find this.
(2,715 Views)
I'm sorry that you have not yet received a response. The information on which version of IMAQ is compatible with each version of LabVIEW can be found in the NI-IMAQ and NI-IMAQdx Compatibility with Different LabVIEW Versions document. The same information regarding the Vision Development Module can be found in the Compatible Versions of Vision Development Module with LabVIEW and LabWindows/CVI document.
Let us know if you need further information.
Matt
NI Community Team
(2,673 Views)
