While loop iterations
I have copied Fig 4-11 from the labView core 1 manual and attached it. The text states it will stop when enabled and the value exceeds 10. It stops on numbers greater and less than 10.
Also if I run it with the switch disabled the iterations indicated are not integer. Why is that? I thought the while looper counter would always be integer.
thanx,
jh
(3,166 Views)
Accepted by topic author jvh75021
Switch enabled: only chance of stopping is when the random value is exactly, and I mean exactly equal to 1.  If I remember correctly, this is not possible 0 <= rand < 1.
The iterations are integer values, if you expand your indicator you will find the exponent since the display is in scientific notation.
Message Edited by Darin.K on 01-15-2010 12:20 PM
(3,162 Views)
Boy howdy, DUH on me for sure.
(3,139 Views)
