Why Do I See Unexpected Value Change Events for Shared Variables Using LabVIEW DSC I dynamically registered value change events for shared variables using the "Request Value Change Notification.vi" in LabVIEW DSC.
Why Do I See Unexpected Value Change Events for Shared Variables Using LabVIEW DSC I dynamically registered value change events for shared variables using the "Request Value Change Notification.vi" in LabVIEW DSC. When I run the VI, I intermit get multiple value change events fired even though the shared variables have not changed at all. This is a case that does not happen at the beginning.  Why am I seeing these events and how can I prevent them?
(2,369 Views)
You may get an initial event on startup which is normal.  Also make sure that you have not enabled timestamp change events.
(2,362 Views)
