Why am I getting Error -229771
Hi
I recently downloaded labview with the purpose of writing a script that would take in voltage measurements of a battery using the NI-USB 6008. My code had been running just fine until I extended my labview trial for the 45 day period. I keep receiving Error -229771 referencing my DAQ assistant. Is there any way for me to fix this??
(3,574 Views)
Accepted by topic author Mmoon
Did you search the forum for the error code? There are a few posts showing solutions.
For some reason you have to leave the minus sign off for the the search to work.
This might be a good place to start:
Why Do I Receive Error -229771 at DAQmx Start Task.vi?
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,544 Views)
