labview for keithley 595
Did anyone have experience of wirting labview program for keithley 595?
I need your help!
I went to www.keithley.com , but I found nothing  .
Help me, please.
(4,180 Views)
If there is no driver, it means you have to program it yourself. First have a look at the manual, it should contain a part what kind of commands are available to use via RS232 or GPIB. Also, you need to decide what kind of hardware interface you wanna use: GPIB or RS232?
After you decided which interface to use, you can test the commands first manually using MAX (Measurement & Automation Explorer).
Finally you can program your own driver VIs using VISA:
https://www.ni.com/visa/
edit: example program to find --> Open LabVIEW, and go to "Help" menu --> "Find examples..." --> Type "GPIB VISA" into the search field, and open the example VI called: "GPIB with VISA functions.vi" . This can give you an idea how to program your hardware.
(4,172 Views)
Hi, I ask a question about writing labview for Keithley 595 a few weeks ago, and you answer it.
First, thanks for helping me. However, when I use instrument assistant to write my command, it didn't work.
According to the manual, the first step is entering "REMOTE728", where 28 represents address and 7 represents controller's interface select code.
I wonder what controller's interface select code is. I entered "REMOTE028"~"REMOTE928", but it didn't work.
Another question, Keithley 595 is a 1980's product. Is there any chance that Labview's instrument assistant is too new for Keithley 595.
Therefore, I can't use Labview's instrument assistant to control  Keithley 595.
Thanks for helping me.
(4,072 Views)
You should check the address numbers and try the steps as described in the manual.
That is all I can help, also you might ask for help from the manufacturer...
(4,062 Views)
I think you need to put a space between the command and the numbers.
Bill
CLD
(Mid-Level minion.)
(4,060 Views)
