Why arent my sensors working?
I've got a single board RIO and a few sensors. I cant get the sensors to work. More accurately, the sensors are working, but LabVIEW isn't giving me correct values. I checked the pin-values with my multimeter and the sensor works correctly.
The frontpanel always shows that the sensoroutput is allways high, but when I measure on the actual pin, the voltage is at 15mV. Even when I connect the pin directly to a ground pin, it still says its high (tried the same with a 5v pin and it also gives a high level).
I added a picture of the FPGA code i used (simple as it may be).
Can somebody help me?
(3,122 Views)
I have not used FPGA but the image you showed is a Digital I/O connected to a binary indicator.  Where is the sensor connected?
Lynn
(3,110 Views)
The FPGA controls all the I/O on the board. The sensor uses 3 pins: 5V, GND and one pin to detect high level/low level (Port5/DIO3). The FPGA module forwards the value to the other processor to enterpret.
Thanks for trying to help, I'm really aching for help.
(3,098 Views)
Accepted by milo_unlimited
Dear milo_unlimited,
please notice that you connected a boolean true to the conditional terminal of the while loop; the loop wil execute only once.
Martijn S
Applications Engineer
NI Netherlands
(3,067 Views)
Which explains a lot.
Thanks!
(3,045 Views)
