Why can't I find "Data Transfer and Memory " option in channel property node?
Hi All,
I'm trying to find some properties such as "Data Transfer and Memory " in my "DAQmx Channel" property node, as below
But, in my Labview 8.5, I can't find it. I re-installed NI-DAQmx, but it didn't work. What I can get is
Did I miss something? Thank you.
Bo
Message Edited by foolooo on 10-23-2008 07:02 AM
My blog Let's LabVIEW.
Message 1 of 9
(3,922 Views)
I too had faced the problem but after a fresh installion of LabView 8.5 and Drivers. It worked.
Regards
Aks
(Appreciate answers by giving KUDOS)
Hit the stars.............. sky is not the limit.
Message 2 of 9
(3,919 Views)
Hi Akshath,
Thank you for the quick reply. I'll try that. (Once it works, I'll set your reply as KudosRobot Very Happy) Thanks!
Bo
Message 3 of 9
(3,914 Views)
I uninstalled all the NI software, and re-installed LabVIEW and DAQmx again, but sadly it didn't work. Thanks any way. But is there some other suggestion?
Best wishes,
Bo
Message 4 of 9
(3,895 Views)
Hi, Bo,
May be you should configure DAQmx card in Measurement and Automation Explorer?
Unfortunately I haven't DAQmx card right now in my PC, so, its just an idea...
best regards,
Andrey.
Message 5 of 9
(3,892 Views)
Hi Andrey,
Thank you for your reply. But I tried this on another computer on which lv 8.6 was installed, and it worked. I just simply dropped the channel property node, and didn't connect with any channel vi, and there were available options on that one. But for this pc, it doesn't work. I also configured the hardware in Mea & AE, it didn't help.
btw, my labview is full licenced.
Best wishes,
Bo
Message 6 of 9
(3,889 Views)
Hi
So now the better way is to call NI Support and explain the problem.
Regards
Aks
Message 7 of 9
(3,871 Views)
Accepted by topic author foolooo
Hi Bo,
Take at look at this knowledge base article.
AE KB 3ESBHEL2: Missing Properties in DAQmx Property Nodes
Let me know if this solves your problem.
Regards
John P
John.P | Certified LabVIEW Architect | NI Alliance Member
Message 8 of 9
(3,863 Views)
Yes, it works! Thanks a lot!
Bo
Message 9 of 9
(3,855 Views)
