how to use event to show 3d model
my vi displays measured process data on front panel from continuously collected data (in a while loop). how do i also map data to a 3d model which can be accessed by user from clicking on front panel i.e. on mouse click - show 3d model on screen, further mouse click returns to orig screen?
(2,735 Views)
hi,
to show data in 3d module  u have to parallel while loop for Acquisition and u call that 3d module vi in that loop this will not effect the acquisition...
Santhosh M
Santhosh M
(2,723 Views)
Hi cj2,
Your application sounds very interesting, could you please be a bit more specific on exactly what you are trying to do (e.g. what you are acquiring, how many channels). Maybe attach your vi or some screenshots of it so I can look into this further? In the meantime here is a Knowledge Based Article (with an attached demo vi in it) that should help you out with displaying the 3D model on the front panel
http://digital.ni.com/public.nsf/allkb/CCE3C1DC149C3A35862574B800734FB4?OpenDocument
Please get back to me with the information mentioned above.
Kind Regards
Ben L
Field Engineer
(2,696 Views)
