Why can't I rename my daqmx device
I built a runtime installer from labview and then even downloaded daqmx from your website. In max I don't have the ability to rename my PCI-6110 or open up the instrument panels? I get a serial number instead of dev 1 and my program won't work as a result. Why is this? I selected every daqmx component possible. Is there something else I'm missing?
Message 1 of 8
(4,915 Views)
Did you reboot after install?
Message 2 of 8
(4,901 Views)
Yes. Several times.
Message 3 of 8
(4,895 Views)
What version of MAX?
Message 4 of 8
(4,884 Views)
14.0.0f0
Message 5 of 8
(4,879 Views)
this is just a WAG, but does the device need a separate driver to be installed?
Message 6 of 8
(4,872 Views)
I doubt it. It didn't need one when I used 2009 SP1.
Message 7 of 8
(4,856 Views)
Try deleting it from MAX and then adding it again.
Or resetting your MAX configuration and then rebooting.
Lastly, dry reinstalling MAX.
Since so many pieces of software depend on MAX, you'll probably have to reinstall other NI software if you go this route.
Casey B.
Message 8 of 8
(4,831 Views)
