Why can't I use picture to pixmap.vi in LabVIEW RT
LabVIEW version 2012 SP1
I found that LabVIEW PC spport "picture to pixmap.vi " but not in RT.
How do I convert a picture content to LabVIEW image data type without "picture to pixmap.vi", the cluster one (not IMAQ purple wire)
The other things, picture functions, work pretty fine.
Temporally, I use invoke node to get LabVIEW image data type. That's is not a good idea because once you fold it into subVI it won't work anymore.
Anyone can help or give me some suggestion?
Best,
Justin
(2,610 Views)
Hi Justin,
Could you please confirm that the NI-RIO version is the same between Windows and RT OS?
It would be better if you can further provide your version of LabVIEW and the rest of all the corresponding software.
Also, please attach your simplified project that allowing us to reproduce the issue.
That would be more specific and more efficient.
Thank you
 Ting
(2,576 Views)
