Sudden Error -200077
I have a measurement system thathas been running for some time that, without any apparent change to the hardware or pc that is running it, has begun giving an error: Error -200077.
It running with Labview 8.2.1, cDAQ9172, and a few modules
The full error discription is:
Error -200077 occurred at Property Node DAQmx Timing (arg 5) in DAQmx Timing (Sample Clock).vi:1->Instance          37  3PAI .vi->PAI.vi->wagu.vi
Possible reason(s):
Measurements: Requested value is not a supported value for this property.
Property: SampClk.Rate
You Have Requested:  0.000000
Valid Values Begin with:  22.250739e-309
Valid Values End with:  6.666667e6
Task Name: _unnamedTask<0>
Could it be a hardware failure, or a change to WindowsOS that could cause this?
(2,928 Views)
Probably neither.  More likely it is a flaw in your code that is now sending the value of zero to the DAQmx timing property node.
(2,916 Views)
Possibly, but why would it start occuring after happily running for 2 years?  Its on startup so its not an unusual path in the program execution.
(2,901 Views)
