capture image from android camera
Hi everybody,
I want to broadcast video from the camera of my tablet android.
          - mode of transfer via bluetooth.
          - I need to receive that video in LabVIEW.
I download WOWebcam Lite application for tablet.
This app create a virtual device in my MAX (Measurement and automation Explorer).
First I check whether I can see my android virtual device in MAX and I try grab and snap, but it does not work.
Therefore it can not work in LabVIEW.
Please help me to solve this problem !
I discussed it here: http://forums.ni.com/t5/LabVIEW/Integrating-Android-Devices-Camera-with-NI-Vision-Software/td-p/2481...
Thanks.
Message 1 of 9
(5,604 Views)
Is it possible to post screenshots also?
-Are you getting any error? or simply nothing happens??
-Did you download PC client also for WO Webcam Lite which is available here http://www.wirelessorange.com/wowebcam/install.html
-First connect through PC client>>Connect>>Bluetooth>>select your device(if it is not visible, then you need to install bluetooth drivers for your tablet in PC).
-When the PC client is ON, try the grab and snap in MAX ( I did not try this with Bluetooth mode, but it was working with WiFi).
uday
Message 2 of 9
(5,567 Views)
when i connect the device and configure the connection from wo webcam client from pc, the connection rest only 4 or 5 seconds then it close automatically, and the image was black .
Bset regards
Message 3 of 9
(5,537 Views)
-Did you read my first question in comment?
-It is very difficult to troubleshoot without looking at what you have done?
-Please can you explain in detail what you have done so far and what exact problem you got with screenshots?
uday
Message 4 of 9
(5,503 Views)
Thank you for your responses.
Your question : Are you getting any error? or simply nothing happens?
- When i connect the device and after that i have this error which is attached below.
- And nothing happens.
Best regards
Message 5 of 9
(5,475 Views)
Sorry bary,
-I am not getting exact problem.
-Can you explain a bit more in detail of what you did and what happened?
-Are you able to connect your tablet to your PC via bluetooth first?(first check with sending some files from pc to tablet and vice versa).
-What do you mean by black image? show the screenshot!!!
uday
Message 6 of 9
(5,378 Views)
First I connect my tablet with PC and the connection work when I send data.
But in the case of image of camera WOwebcam, I haven't any result.
When I connect the WOwebcam based on stapes of connections which explained on "Help" attached with the program, the application didn't work and I haven't any image.
Thanks.
Message 7 of 9
(5,336 Views)
Accepted by topic author OmarBahri
Thanks.
Message 8 of 9
(5,335 Views)
Thank you for your responses Smiley Happy
My problem is solved.
Best regards !
Message 9 of 9
(5,128 Views)
