Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Why do I get Error 1 when building applications
yen78
Member
01-06-2005
12:33 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm creating an executable using the Labview 6.1 application builder but I get this error: Error 1 ocurred at Gsim Sintax Check.vi. I didn´t install the Simulation and Control toolkit I copied the vis I needed to use them.
What can I do?
Kudos
Message
1
of 2
(2,496 Views)
Reply
Re: Why do I get Error 1 when building applications
Brett_B.
Member
01-07-2005
01:45 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
yen,
Do you get this error at build of the application or from the executable itself? Does the VI run in the development environment?
I would build the executable from the development machine that has the toolkit on it.
Brett B.
0
Kudos
Message
2
of 2
(2,481 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
