Why do I get "you have connected two terminals of different types"
The polymorphic selection is OK, because you have the DBL array coming out of the VI fine, and there doesn't appear to be anything wrong with the subVI, because you would have seen a "subVI is not executable" error.
The fact that the sink is recognized as void causes me to think that there may be something wrong with your LV installation. The only way I managed to recreate your error was by going into the subVI and disconnecting the FP IO control from its terminal in the connector pane and then reselecting that polymorphic instance (because the automatic selection immediately changed it when I disconnected it).
Try looking inside the subVI to see how its connector pane is set up. Use what becktho suggested to check all the polymorphic instances. If you do find that it's disconnected, you should check the other FP VIs as well. Then, I suggest you post the actual temp measurement VI (backsave to 7.0) so we can try it, and the next step will probably be doing a repair on the LV installation.
___________________
Try to take over the world!
Message 11 of 21
(3,637 Views)
Tried reinstalling before, and changing to a fresh VI, but the same happens.  However, over the weekend I hope to install it on a different PC and see where things go from there.  I'll keep you all informed! Smiley Wink
Message 12 of 21
(3,623 Views)
I have the same error "These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match. Show the Context Help window to see what data type is required.
The type of the source is word [16-bit integer (-32768 to 32767)].
The type of the sink is DAQmx Device." but i can't find the option about "disable indexing" at all. where it is?
Vi i used is the first example0 "RC Transient.vi"
Message Edited by sesp on 11-14-2005 05:11 AM
Message 13 of 21
(3,602 Views)
You don't need "enable indexing" as this has to do with loops.
Just delete the constant you wired. Point to the terminal with the wire-tool, right-click and select create constant.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 14 of 21
(3,592 Views)
it doesn't work 😕 something else i can do please?
Message 15 of 21
(3,592 Views)
Doesn't work 😕 something else i should try?
Message 16 of 21
(3,587 Views)
Try an "DAQmx Device Name Constant" (see picture).
Why did my previous suggestion not work?
Using LV8.0
Message 17 of 21
(3,583 Views)
Just now I tried to create one diagram after managing to do it Simulink. http://postimg.org/image/hswnsla0h/ But I got the error on the type compability, to be more exact On array and one-unit item compability of the same type –despite I have no similar error in SL. Should I correctly understand that I cannot fork the wire more tan once. If I have the wire could I branch it to for example 6 items? I refer here the image. In the second case I have the same error with Boolean type. I subtract two numbers and its checked twice is it >=0 or NOT equal to 0, than go inside the selector function but it evokes the error. Here it forkes just once?? So what I need to do here. Should I build array here? http://postimg.org/image/3ldn2d2q3/
Message 18 of 21
(2,881 Views)
Instead of adding a new message to the end of a long, 10-year old thread.  Just continue in your original thread!
http://forums.ni.com/t5/LabVIEW/How-implement-analog-sorting/td-p/3140961
Message 19 of 21
(2,874 Views)
I got the same problem, the representation is double and they all have the same length of data but cannot be connected either to xy graph or waveform graph.  What could be the problem?
Message 20 of 21
(1,783 Views)
