Why does NiVisaServer.exe is running when Labview is running??
I am running two identical test setups for some system testing.  The PC configuration and test cases are same on both the setups. I am using  Labview version 8.5 . I observe the setup running with NiVisaServer.exe is slow as compared to the other setup. The same file is not running in the other setup.  My question is , does NiVisaServer.exe slow down the Labview execution?? Why does NiVisaServer.exe is not running in the other tester eventough both are identical??
(2,615 Views)
More than likely it might have been accidentally set to start up when the PC starts. See attached screenshot for where this is configured in MAX.
(2,606 Views)
