unbundle waveform
hi,
for some reason i can't unbundle the attached waveform in the vi attached.
i used get waveform components vi and it won't work.
thanks,
(5,127 Views)
You have an array of waveforms.  You will need to use Index Array to pick out which waveform you want, then you can wire that to the Get Waveform Components to unbundle the components you want.
(5,124 Views)
sweet,
 thanks
(5,106 Views)
