Why does every compile produce a different binary file
We are using a new configuration management tool and due to this we had to prove that we could take projects back out and reproduce the original binary files. Every time we tried this the new binary file matched the original in terms of size, but the actual data had differences.
After a bit of experimenting it was noticed if you force CVI to recompile a project you can never get the exact same binary file, even a recompile straight after making the first one. Anybody now why this is the case, or why we are seeing this?
Creating custom step DLL's to be used in Test Stand 4.0 with CVI 8.0.1
Thanks in advance
(3,545 Views)
I take you use CVI, while you posted in the LabVIEW board.
However the builds made with LabVIEW have some additional info that is related to the actual build time. I guess the same goes for CVI (and many other compilers).
Ton
My LabVIEW Ideas
(3,538 Views)
You've posted this in the LabVIEW forum. You actually want the LabWindows/CVI forum.
(3,538 Views)
That was our initial take, that it would just be time stamps information. Until that is we used a comparison tool and there were differences throughout the files and sometimes in blocks that were just too big to be time stamp information alone.
(3,504 Views)
ps sorry for posting in the forum, I have now reposted in the correct forum
(3,500 Views)
