digital toggle switch
hi
 i have started learning labview now a days, today i am creating a digital toggle switch, what i am doing in this attach program is that to set the time for both low pulse and high pulse, so that when it start it should toggle the output from 0 to 5 and then 5 to 0 volt every after defined time, but i have problem that it is not toggleing. need help to fix this problem,
thanks,
vi is attached
thanks
best regards
qazi
(3,981 Views)
Your code looks pretty straightforward.  What kind of on/off times are you trying to generate?
How do you know the digital output line is not working?  What kind of equipment is that digital line wired to?  What kind of DAQ card are you using?
(3,953 Views)
Hi Qazi
Like Ravens Fan said, what kind pulses are you trying to generate and on what equipment? I ran your code on a both a simulated device and a DAQcard and it works like described it, so my best advice is to chck the connected hardware
Best Regards
David
NISW
(3,871 Views)
