reshape with daqmx
hi
We use a Daqmx PCI 6251 to acquire and send signal to generate pulse (for measurement strain), But i need to reshape frequency of pulses because is too high.How can i do it?
Mariangela
(3,184 Views)
Hi Mariangela,
I'm not sure to have understand what you want to do... Could you explain it using another words?
thanks
Mate
Matteo Brunella
Application Engineer
NI Italy
(3,164 Views)
Hello Mariangela,
I didn't understand completely your question.
I assume you're using a counter of the PCI 6251 in order to generate the pulse train. If you want to vary the frequency of the train, performing a PWM you can take a look at the following link:
Pulse Width Modulation (PWM) Using NI-DAQmx and LabVIEW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1P0CAI&l=en-US
Let me know if you need more help.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(3,156 Views)
