Why does my FPGA compilation stop?
Hi all,
I'm using a Asus N76VZ with 16Gb Ram and Win 8.1Oem.
I use LabVIEW 2013SP1 with RealTime SP1 and FPGA SP1 module with Xilinx 14.4 ISE (plus f1 patch), but I can't compile any FPGA VI.
I'm trying all the suggested action explained in this thread, but nothing change. I have changed the DLL and set the CompilerWorker.exe (and other files exe) with Win7 compatibilities. NO results.
I can't compile!
I contacted a NI AE --> he said that is a compatibility issue.
Is it possible that there isn't any solution?!?  😕
Bye to all
Message 11 of 13
(936 Views)
Hi GVorraro!
As stated earlier in the thread, unfortunately, compilation is not officially supported on a Windows 8 machine.  Also, you have posted on a fairly old thread, you might be able to get a better responce from the community if you make a new post!
Tucker
Applications Engineering
Message 12 of 13
(898 Views)
I think the work around is to use the FPGA Compile Cloud. This is included in the SSP when you buy FPGA Module.
Message 13 of 13
(873 Views)
