Why does my IMAQ Find Circular Edge tool give a result in pixels instead of um when I migrate from Vision Assistant to a VI?
I have a very simple script in vision assitant.  I open a picture I have previously saved that just has a light circle on a dark background.  I have previously taken a picture of a grid of dots that has yielded calibration info in micrometers.
In Vision Assistant, my steps are:
Orignal Image--->Image Calibration 1--->Circular Edge (Spoke)1
This works, and gives me a result of the center x and y of the circle in pixels, the current radius in micrometers, and current deviation in pixels.
From Vision Assistant, I used the Create LabView VI tool to make a Labview VI of this very simple process.
However, on the front panel of the VI, it returns the Best Circle Center X-Y and Radius in pixels.
I have found no option to change this.
I also posted this in the Machine Vision forum.  I apologize if that makes people mad--after I posted it there, it seemed to me that it's more of a software problem than hardware problem.
(2,768 Views)
Dear SuperFly,
I created the same script in Vision Assistant, and then created a LabVIEW VI from this script. I observed the same behavior that you did: The radius was returned in my calibrated unit in Vision Assistant, but in pixels in LabVIEW.
Take a look at the post below. It explains that this problem is a noted oversight in the Vision Assistant, and gives the solution.
Troubles when creating LabVIEW VI from Vision Assistant
Best Regards,
~Nate
________________
NI Applications Engineering
(2,754 Views)
I was able to get a workaround using help from folks in the machine vision forum at this thread:
http://forums.ni.com/ni/board/message?board.id=200&thread.id=17121
(2,744 Views)
