Why does my point-by-point signal generator give a flat line?
 Hi all,
I am using the point-by-point VIs for the first time and am trying to generate a square wave using them. However, when I plug the output from a point-by-point square wave generator, it just gives a flat line (using both default values and various values for the other parameters). But it works fine if I use the point-by-point noise generator, it shows up fine in the chart. Any ideas?
Cheers
(4,407 Views)
hello ,
i think you surely forget the time base ...
also take care to use step time < 0.5*fmax
see vi joined
Tinnitus
Message Edité par tinnitus le 12-15-2008 06:37 PM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(4,401 Views)
Hi, sorry to trouble you, but can you send the VI as a Labview 8.5 VI? thanks!
(4,381 Views)
Accepted by topic author andrewong
 done ....
(4,377 Views)
