Why does the HTTP get function returns the error code 63?
I trying to use the HTTP get function to get the XML file is returned from the Google MAPS api distance-matrix. I receive the right answer if I insert the url directly on the browser but using the HTTP get function it returns the error 63, why?
This his is my code (the VI is developed on LV2011).
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
(3,458 Views)
Accepted by topic author g_Ricky
I guess, the GET VI intended for using with LabVIEW Web Service, not for obtaining pages from Internet.
Use more simplest way:
Andrey.
(3,451 Views)
Thank you very much for the trick. It seems to work very good!
Ricky
(3,448 Views)
