Why does the connector pane show different connector for lvclass?
Picture is worth 2000 words...
What's the special deal with the top left & right connectors?
I have other lvclasses, but they do not have the X-shaped dots..
(2,576 Views)
Accepted by topic author Ray.R
Those are connections marked as Dynamic Dispatch (have a look at where you would set it to be required). A DD input means that this is a VI which is designed to be overridden dynamically at run-time based on the type of class actually present on the wire.
___________________
Try to take over the world!
(2,564 Views)
