Why does the mouse position update on one of these VIs and not the other?
I have attached two VIs. Both are very simple while loops designed to return the position of the mouse on a picture control. Can any one tell me why one of these successfully returns the correct mouse position while the other does not? They appear exactly the same as far as I can tell. Running the "Compare" tool on them only turned up aesthetic differences.
Message Edited by William Griffin on 10-05-2007 11:20 AM
William Griffin
NI Certified LabVIEW Architect
NI Certified Professional Instructor
DISTek Integration, Inc. - NI Certified Alliance Partner
http://ww2.distek.com
(2,601 Views)
In A.vi, your zoom factor for the picture is set to 0.  Set it to 1, and the VI works.
(2,589 Views)
I recommend filing a bug report to NI that the ZoomFactor property is not detected when doing a compare on the two VIs.
-D
Message Edited by Darren on 10-05-2007 11:30 AM
(2,589 Views)
I tried to file a bug report. I clicked on the bug report link under contact NI and followed the steps. Apparently the typical bug reporting method is to post them on the forum?
William Griffin
(2,575 Views)
