is there VI's available for image read/write file operation for image aquistion using imaq usb VI's?
I need to write to and read from a file, images acquired using imaq usb VI's, the imaq buffers VI's are not compatible with the usb VI's. I need to be ale to write a sequence of images to file and retreive them for analysis very quikly.
(2,955 Views)
Hi Brendan,
I'm attaching an example which will stream the images to an AVI file. This takes about 3ms per frame.
Hope that helps
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(2,940 Views)
Hi Sacha,
I have used a similar VI to write image from IMAQ USB to avi file like yours, however it doesn't work with "incompatible image size" error, other guys suggested to use different size avi files and this does not work as well.
How does your test VI work?
thanks
(2,750 Views)
Hi hannah,
Does the error message point to a specific VI, such as saying "incompatible image size occurred at AVI Write Frame" or give an error code?  One possible cause of this message is that the incoming images are changing size, which you can check by using the IMAQ GetImageSize VI.
Carlton
CLA
(2,734 Views)
