‎06-25-2010 12:44 PM
If I configure an AI channel using DAQ assist why would I convert it using the Generate NI-DAQmx code from the menu? Does it run faster ? What is the advantage of converting ?
Dave
Solved! Go to Solution.
‎06-25-2010 01:50 PM
1: Because you would prefer to know what your code is doing under the hood rather than just guessing and hoping it's right.
2: It's a great way to learn.
3: In most cases the "Wizards" generate safe code instead of efficient code so it often runs slower than it would if you optimized it.
4: You will eventually move beyond what it can do for you automatically but it's still a good way to jump start your project. (Same with modifying the NI example VIs.)
BTW, no doesn't run faster UNTIL/UNLESS you find a way to optimize it.
‎06-25-2010 02:26 PM
Also, you have more control over DAQmx code vs express VIs. If you need to configure parameters that were not in the express VI, like exporting a trigger to cause another instrument to trigger, you could add code to do so.
Finally, the express VI probably contains more functions than you actually need. A lot of unnecessary code. With DAQmx, you only put what you use. No unnecessary functions wasting time.
‎07-01-2010 12:58 PM
Thanks for all the responses
