Why is For/While loop Iteration I32?
I like the idea as well.  Just make it similar to the new 'conditional terminal' option.  Right click, and you can then include a 'base' and 'step' terminal, just below the N on the top left.
Simple and powerfull.   And doesn't sound very hard to implement either...
Message 11 of 38
(3,083 Views)
Hi everyone,
I thought I might show everyone the product suggestion center on NI.com.  Engineers actually look at these so they don't simply go into a black hole.
Eric A.
Distributed I/O Product Support Engineer
Message 12 of 38
(3,061 Views)
It was already suggested quite articulately. Smiley Happy
___________________
Try to take over the world!
Message 13 of 38
(3,042 Views)
One problem that would need to be addressed is the current restrictions of array indices to I32. So if you have a U32 loop, you could easily create an autoindexing output that exceeds the currently allowed array size. Still, on a 32 bit OS, it would be hard to exceed that size anyway (at least in memory) so I am not sure why that extra factor of 2 (going from I32 to U32) would ever be useful.
Did you really run into a limitation because if I32? Can you show an example?
(Maybe in a few years we'll have a 64 bit LabVIEW with I64 array indices and I64 FOR loops. ;))
Message 14 of 38
(3,031 Views)
Eric, is there a way to see what's allready suggested to the 'product suggestion center' ?
Message 15 of 38
(3,010 Views)
Hi Anthony,
Unfortunately NI doesn't make that information available to the public.  However, we would like encourage everyone to make a suggestion for every good idea they have, even if it might have been suggested already.
Eric A.
Message 16 of 38
(2,968 Views)
I am new to LabView.I want to run iteration for negative i as well.Can you pls suggest me a way to do that...??
Message 17 of 38
(2,586 Views)
How is that supposed to work?
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 38
(2,577 Views)
As of now i am doing it with adding 'i' with a negative number and making some further manipulations to get my work done but it makes it very complex.I think there must be some easy way out to this.As i was searching on forums, i came across use of "arrays and/or clusters" for making configurable for loops but i couldn't comprehend that.In case it can't be done using for loop ..u may suggest some other way.I was wondering if i would make my own counter using some way(as mentioned in this post as one of the replies),will it serve the purpose..??
Message 19 of 38
(2,575 Views)
You are trying to iterate through an array backwards?  If that is the case, then just use a Reverse 1D Array function in there and then autoindex on your FOR loop.
If I'm misunderstanding, please provide an example of what you are trying to do.
Message 20 of 38
(2,573 Views)
