wire function conflict
I'm trying to programmatically call a VI within a loop (by reference) but am having trouble managing the vi reference, which I need to generate from a filepath sent through a queue elsewhere in the code.
I have a user-generated event working which opens a file path, sent from a different section of the code (see images below), and I am able to create a reference within the event structure. However, when I try to populate an element in a cluster, an error occurs: the wire is broken, and it says 'wire: function conflict'. I thought the issue might be that a type-def'd or strictly type-def'd should be used inside the cluster and tried this but still had the same error.
If anyone could explain what the issue is here, and how I can generate a reference for a vi filepath sent from another part of the code, and then put it into a cluster so that I can run a VI by reference, that would be great.
Earle
(3,240 Views)
You have a strictly defined VI reference.  Your cluster needs to match the strictly typed VI reference.
(3,235 Views)
Hi Crossrulz,
Thanks for the reply! I thought this might be the case, and I tried to do this inside the cluster, but perhaps I did it wrong.
I created an idicator wired to the output of the VI reference, ran the program so that the indicator updated, created a control from that indicator, then copied the control into the cluster and strictly type def'd it. Was I meant to do it differently?
Earle
(3,205 Views)
