Why is LabVIEW using "Background Intelligent Transfer Service" a.k.a BITS?
I have created a LabVIEW executable. When I run it, Win 10 Task Manager shows that the Exe is using MS Background Intelligent Transfer Service (BITS).  I have never seen this before. I brought it up to my IT group and they inform me BITS could be pose a security risk. I did a little digging and found these articles
https://resources.infosecinstitute.com/topic/how-criminals-are-using-windows-background-intelligent-...
https://learn.microsoft.com/en-us/windows/win32/bits/background-intelligent-transfer-service-portal
As long as my windows is kept up to date on my development machines and all the system on which the Exe is deployed, should this be a problem? I am still curious to know why and what in my Exe is triggering this service.
Message 1 of 8
(3,267 Views)
You have not described what your LV exe does.
Quoting from the MS web site: "Background Intelligent Transfer Service (BITS) is used ... to download files from or upload files to HTTP web servers". Is your app doing that?
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
Message 2 of 8
(3,254 Views)
Sorry, no. My Exe does use TCPIP functions but only over to a private network on a separate ethernet card. It does not go out over internet or even on our network.
Message 3 of 8
(3,244 Views)
I will defer to someone that knows what they are talking about
Message 4 of 8
(3,232 Views)
I don't think that where it is going isn't important; it's what you are doing.  Apparently you are using HTTP to transfer files either to or from a web server, as was mentioned above.
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(3,225 Views)
I am only using TCP function to local IP addresses. I do not use any HTTP functions. I do use some DB function that do go over our domain network to retrieve stuff from the DB. I guess it's more of a generic question.  So do HTTP function use this MS BITS service?
Message 6 of 8
(3,217 Views)
Instead of links to random other pages, can you instead post a screenshot of your task manager where it show that you LabVIEW application is using BITS?
Message 7 of 8
(3,151 Views)
Yes, considered that. I had already closed the exe. When I ran it again, the BITS service was not there., meaning under my Exe in Task Manager. Very odd. I'll keep an eye on it and if I see it again, I will take a snapshot and post it. I can describe it as being indented under my Exe in the Task Manager listing under the Apps category.
Message 8 of 8
(3,127 Views)
