Why is my LV8 SubVI a clone?
So, is the solution to select the VI, enter its VI properties, de-select reentrant, make your edits, re-select reentrant, save?
Message 11 of 14
(980 Views)
No, select
View\Browse Relationship\Reentrant Original
in the Menu. Then an additional copy of the SubVi will open which is not a clone.
Problem is, that this is quite annoying.
Message 12 of 14
(970 Views)
i am using labview 2011, it behaves the same thing!!!
and, i am stil troubleshooting if this causes my that particular block diagram to be slow....
1. does clone sub vi causes slowness?
thanks
Message 13 of 14
(633 Views)
With a Reentrant VI you can go to Edit mode (ctrl+m) and you should get the change the original.
Reentrancy doesn't cause slowness.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 14
(626 Views)
