12-11-2007 12:57 PM
12-12-2007 07:23 AM
Re:a.plugaru
Ben
12-12-2007 08:49 AM
I am going to put in a product suggestion for an enhanced Decoration Object, can be used in that same way as decorations with additional functionality.
Properties
Bounds <H, W>
Possition <T,L>
12-12-2007 08:53 AM
Properties
_______________
Bounds <Height, Width>
Position<Left, Top>
Color<FG, BG> A color array would be nice but will be harder to keep compatable
Size<W, H>
Label : this is never shown but allows for referencing decoration directly without keeping track of indexes.
12-12-2007 09:06 AM
IGNORE last two submitted messages here is the correct message, my browser was acting up.
Properties
_______________
-BOUNDS <Height, Width>
-POSITION<Left, Top>
-COLOR<FG, BG> A color array would be nice but will be harder to keep compatable. 32 bit color with alpha blend would be very nice
but this is a different can of worms.
-SIZE<W, H>
-VISIBLE?
-LABEL: this is never shown but allows for referencing decoration directly without keeping track of indexes.
-POLYLINE: array of points (X,Y) from origin for defining the vector graphic (provide an editor tool), this will accuratly scale
decorations with size changes of the bounding rectangle.
-PATTERN: 2d array of texture to fill polygon with
-BLEND: if pattern is not used, allow for blend from color A to color B allong a specoified vector ie (red to white allong the unit vector 1,1
provides a Red phase out from the upper left corner to the lower right)
-ROTATION: 0-360 (int%360) rotates image about center by specified degrees.
-TRANSPARANCY- 0-100% allows for blending and object overlap.
METHOD (in addition to the usual decoration methods)
________
ADD_POINT - inserts a point into the polyline at a specified index
REMOVE_POINT -removes a point into the polyline at a specified index
This is what I have in mind. Feel free to add or comment.
Paul
12-12-2007 09:21 AM
12-13-2007 04:14 AM - edited 12-13-2007 04:22 AM
12-13-2007 07:51 AM
Xcontrols might work but I still would like to see a native object called an enhanced decoration. The problem with an Xcontrol (I have been limited on my use) is that this as not really a control (see lv class hierarchy) there is no data publicly avaliable. The object as BEN pointed out must be very light weight, requiring little processor time. I will be very interested to see an XControl however. This would be the closest way that the community can solve the problem. My main use for these decorations though will be to customize Labviews controls, and Xcontrols wont work for that since you can not have two controls customizing a control, just add decorations and graphics. Thank you for posting on Lava since the top guns of the community frequent it.
Paul
12-13-2007 08:05 AM
12-13-2007 08:07 AM
a.plugaru,
I reported your abuse as well.
