Why is the decorations so limited?
One possible solution for custom cursors and plots which has been add to v8.5 is a front picture object on plots.  This is essentially a picture object overlayed on a plot with no additional code or controls.  Also you can now customize symbols in the tree and list boxes in the newer versions.  So some progress has been made here but yes the entire interface could be improved.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 11 of 38
(4,528 Views)
Re:a.plugaru
Ben
Message 12 of 38
(4,494 Views)
I am going to put in a product suggestion for an enhanced Decoration Object, can be used in that same way as decorations with additional functionality.
Properties
Bounds <H, W>
Possition <T,L>
Paul Falkenstein
Message 13 of 38
(4,461 Views)
Properties
_______________
Bounds <Height, Width>
Position<Left, Top>
Color<FG, BG>  A color array would be nice but will be harder to keep compatable
Size<W, H>
Label :  this is never shown but allows for referencing decoration directly without keeping track of indexes.
Paul Falkenstein
Message 14 of 38
(4,455 Views)
IGNORE last two submitted messages here is the correct message, my browser was acting up.
Properties
_______________
-BOUNDS <Height, Width>
-POSITION<Left, Top>
-COLOR<FG, BG>  A color array would be nice but will be harder to keep compatable.  32 bit color with alpha blend would be very nice
      but this is a different can of worms.
-SIZE<W, H>
-VISIBLE?
-LABEL:  this is never shown but allows for referencing decoration directly without keeping track of indexes.
-POLYLINE:  array of points (X,Y) from origin for defining the vector graphic (provide an editor tool), this will accuratly scale
  decorations with size changes of the bounding rectangle.
-PATTERN:  2d array of texture to fill polygon with
-BLEND:  if pattern is not used, allow for blend from color A to color B allong a specoified vector ie (red to white allong the unit vector 1,1
      provides a Red phase out from the upper left corner to the lower right)
-ROTATION: 0-360 (int%360)  rotates image about center by specified degrees.
-TRANSPARANCY- 0-100%   allows for blending and object overlap.
METHOD (in addition to the usual decoration methods)
________
ADD_POINT  - inserts a point into the polyline at a specified index
REMOVE_POINT -removes a point into the polyline at a specified index
This is what I have in mind.  Feel free to add or comment.
Paul
Message Edited by falkpl on 12-12-2007 10:05 AM
Paul Falkenstein
Message 15 of 38
(4,444 Views)
It should have a Caption, won't be much extra work...
And having some Events! That would make it a really flexible tool.
(Mouse Down, Mouse Up, ...).
Felix
btw: I hate Christmas Deco 😉
Message 16 of 38
(4,429 Views)
Falkpl,
this could be done with an XControl!
I'll post a propose to the LAVA forums to make a coding challenge on this.
Here's the link to my proposal
Ton
Message Edited by TonP on 12-13-2007 11:22 AM
My LabVIEW Ideas
Message 17 of 38
(4,382 Views)
Xcontrols might work but I still would like to see a native object called an enhanced decoration.  The problem with an Xcontrol (I have been limited on my use) is that this as not really a control (see lv class hierarchy)  there is no data publicly avaliable.  The object as BEN pointed out must be very light weight, requiring little processor time.  I will be very interested to see an XControl however.  This would be the closest way that the community can solve the problem.  My main use for these decorations though will be to customize Labviews controls, and Xcontrols wont work for that since you can not have two controls customizing a control, just add decorations and graphics.  Thank you for posting on Lava since the top guns of the community frequent it.
Paul
Paul Falkenstein
Message 18 of 38
(4,350 Views)
@ a.plugaru:
It's not just Ben... I wrote to NI to remove you from user base because of SPAMing...
Message 19 of 38
(4,341 Views)
a.plugaru,
I reported your abuse as well.
Message 20 of 38
(4,376 Views)
