Why is there no output from the "IMAQ Co-occurrence Matrix" VI?
When using the "IMAQ Co-occurrence Matrix" VI there is no Co-occurrence matrix output. There Haralick features are produced but the co-occurrence matrix remains empty (It should produce a 8x8 matrix). I am inputting a U8 grayscale image with a displacement vector of 1,0 and a co-occurrence level of 8. Using default setting does not produce a matrix either. Any help on this would be appreciated.
Ryan
Message 1 of 21
(4,076 Views)
I too was getting no output from the cooccurence matrix. I'm going to investigate this. In the mean time, feel free to use this example as a workaround https://decibel.ni.com/content/docs/DOC-1084 .
Message 2 of 21
(4,055 Views)
Was just wondering if there has been any progress made on this problem?
Ryan
Message 3 of 21
(4,030 Views)
Still waiting for a response from the platinum team. Hopefully will have some idea for you soon.
Message 4 of 21
(4,018 Views)
Looks like it's a bug. A report has been issued with R&D to fix it.
Message 5 of 21
(4,009 Views)
Installing 2010 SP1 has not fixed this issue, is there a patch for this yet?
Colin
Message 6 of 21
(3,988 Views)
There is not currently a fix for this in version 2011 or below. R&D is currently looking into the issue.
Message 7 of 21
(3,975 Views)
Hi, just wondering when the fix for this will be available?
Message 8 of 21
(3,880 Views)
Kevin did alert R&D about this issue.  I am currently not aware of when the fix for this will be implemented.  I will speak with R&D again to see what there plans are for the fix.
Greg H.
Message 9 of 21
(3,867 Views)
Hi, its been quite a while since this issue was raised. Is there a fix yet?
Message 10 of 21
(3,805 Views)
