Why is there no output from the "IMAQ Co-occurrence Matrix" VI?
It does not appear that the problem has been fixed in the latest release of IMAQ.  R&D is aware of the issue.  There is a post previously in this thread that provides a work around to this problem.
Greg H.
Message 11 of 21
(1,363 Views)
Unfortunately the work around is impractically slow, this problem is holding up part of the project that is migrating code away from Matlab. Is there an indication of when the fix will be available?
Message 12 of 21
(1,356 Views)
I've just tried this with LV 2012 and Vision 2012, and do get a GLCM output.  I also used a displacement of 1,0 but set the co-occurence level to 256 (for an 8-bit image).  Maybe you can try again with the latest software.
There are also two other threads which give some pure LV code to produce a co-occurence matrix which appears to give identical results to the IMAQ function here:
http://forums.ni.com/t5/Machine-Vision/Texture-Analysis/m-p/193054
http://forums.ni.com/t5/Machine-Vision/Is-there-an-IMAQ-Vision-function-that-calculates-a-co-occurre...
There is also code there to compute the Haralick features, and it all seems fairly fast.
Message 13 of 21
(1,351 Views)
Hi Greg,
That's good news, we have the "NI Academic Site License - College Teaching". Do you know when we can expect 2012 to be shipped to us?
Cheers
Colin
Message 14 of 21
(1,349 Views)
No, I don't work for NI - just another user!
Message 15 of 21
(1,343 Views)
Oops, my bad. Confusion between GregS and Greg-H 🙂
Message 16 of 21
(1,340 Views)
I would suspect that you should have already received LabVIEW 2012.  If you have not you can contact your account representative to see why you have not received it yet.  You could also download it from our website.
Greg H.
Message 17 of 21
(1,331 Views)
I found who had been sitting on our copy...
Anyway the Co-occurrence Matrix is still zero length. Which makes me wonder if the upgrade upgraded this bit.
The vi I have is IMAQ Cooccurrence Matrix, Source version 11.0, Current revision 158.
Could someone please advise which version has the bugfix?
Colin
Message 18 of 21
(1,307 Views)
Hi Ryan,
Looking through the bug report (Corrective Action Request or CAR; number 308871) it looks like this bug was corrected in the 2012 (12.0) version of the Vision Development Module (VDM). You can see the 2012 VDM update log that lists this fix here.
Bill E. | Applications Engineer | National Instruments
Message 19 of 21
(1,294 Views)
Vision 2012 is where I noticed the fix.
Message 20 of 21
(1,288 Views)
