01-29-2009 11:05 AM
Sorry, I did not send a corrected file (with detail setting), here it is!
Note: To be sure that I send the right ascii code, I display the sending string in Hexadecimal. Also since when hitting the ENTER key is equal to 0x0D that is why I changed ... but anyway, even I try some thing else with or without after "*debug", it does not work!
01-29-2009 12:23 PM
01-29-2009 03:18 PM
I did try & it also does not work. I also tried to see I am able to send the "*debug\r" out through COM1 (with other Hyperterminal in another PC) & it sends/receives the strings OK (means the VI working file).
However, I just remember 1 thing that is the device has USB connector & after installing its driver, the Virtual COM3 is created.
Might be the Hyperterminal can work with the USB Virtual COM port & NI can not! Because I did try to use the Measurement & Automation Explorer to try Write Vi & read Vi directly and it happen exactly as in LW program
This time might it help to explain my problem?
01-29-2009 03:25 PM
There is no reason why LabVIEW (what is LW?) couldn't communicate with a USB-based RS232 interface (after you have installed all the drivers off course).
Did you set a termination character in the LabVIEW application?
Ton
01-30-2009 11:01 AM
1. The device I am trying to communiacte is EK302DL Evaluation kits & I am not sure NI can support its driver? After installing its driver the Measurement & Automation Explorer seeing the Virtual COM3 & after Seral conflict baudrate between Visa (9600) & Windows (115200), I did correct it successfully!
*) I am not sure NI can support this Virtual COM3!
2. I did try as all of you suggested & it still does not work (sorry about typo-error LV not LW)
3. I also did try with Serial sample CVI that able to set all Serial parameters in Run mode (C:\Program Files\National Instruments\CVI80\samples\rs232\Serial.cws), I also did try to send *debug command with CR or LF or none ... but it also does not work at all (no Serial error happened)
I hope you can know more detail now! I am still trying & trying!
01-30-2009 12:52 PM
I found the problem, as in NI mentioned that Hyperteminal received data with slow typing speed, meanwhile any SW that sends the whole string in one shot! I did send bity-by-bite & it work!
Thanks for trying to help
