Why my XY chart does not work?
Accepted by cookie_monster9
You are correct!
I can not open your example because I run an older version (2013). I will highly appreciate it if you could save to an older format.
Message 21 of 24
(1,206 Views)
Of course. Hope this works for you.
Message 22 of 24
(1,200 Views)
@wentao_ji   i don't come from an engineering background, im just a lowly cs (calisthenics studies)
@cookie_monster9 to whom are you referring with "You are correct"?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 23 of 24
(1,193 Views)
Thank you for the file - this was exactly what I needed. Basically you just build an array and append to it so the data set is suitable for a graph.
Message 24 of 24
(1,186 Views)
