Why the Configure Application Server is locked?
Why Configure the Application Web Server is locked? .....................why can't click to open it.....................
(2,909 Views)
Accepted by topic author aqeelfarooq96
Hi aqeelfarooq96,
Make sure the NI System Web Server is running in your Windows Services.
Control Panel » Administrative Tools » Services
If the NI System Web Server is not running then you will not be able to configure the Application Web Server.
https://www.linkedin.com/in/trentweaver
(2,849 Views)
Thanx mate that you spend some of your time in solving my problem.............Re-installing has solved my problem..........you are right that services are off before re-installation but afterward services would restore ..............
(2,826 Views)
