This widget could not be displayed.
Why the property node is in color red?
I saw the property is in color red as below shows. How to make it color red?
And I notice that the first property does not exsit in the pop-menu, does that mean the propery is in different labview version?
(5,172 Views)
Accepted by topic author MoonSailer
It means the particular method or property has been deprecated by NI and could be removed from the API at some point in the future. There will be a new method/property that does what you want, just dig a bit deeper.
(5,159 Views)
Ye, thank you very much for reply
(5,149 Views)
You probably want to use something like this,
(5,124 Views)
