Why this discrepancy in time functions?
Accepted by CoastalMaineBird
Maybe this is it:
I am on EDT right now.
My client is on CDT.
The TIMESTAMP displays show the time in LOCAL TIME.
Suppose the client actually ran the test from 9:39:20 to 9:59:31 CENTRAL TIME.
The TIMESTAMP is smart (?) enough to know that it's on CENTRAL time.
When HE opens the file, I'll bet HE sees it as 9:39:20 - 9:59:31.
However, when I open the file, the TIMESTAMP display is showing the SAME TIME, but in MY LOCAL time: 10:39:20-10:59:31
That is the exact instant he started the test: 10:39:20 MY TIME.
The  string indicator loses the timezone when it is recorded - it cannot change, so it shows the same thing in any timezone.
That makes sense, I will verify this with him.
Steve Bird
Culverson.com
LinkedIn
Message 11 of 14
(1,137 Views)
Confirmed.   My client (in Central time) opened the SAME data file and it shows 9:39:20 - 9:59:31.
 I wonder if that will change next week (after we switch to standard time).
Steve Bird
Culverson.com
LinkedIn
Message 12 of 14
(1,130 Views)
It will. Like you said the timestamp display uses the PC's opinion of what local time is. I am sure his clock is respecting the time change. The best way to eliminate discrepancies across time zones is to customize the timestamp indicated with the format time string vi.
[will work for kudos]
Message 13 of 14
(1,099 Views)
Actually, it did NOT, at least on my machine.  That same file shows the same time in my case: 10:39:20.
Steve Bird
Culverson.com
LinkedIn
Message 14 of 14
(1,095 Views)
