Why wont typecast allow me to concatenate?
As in the above snippet, I am not allowed to contatenate the output from a type cast. Why?
I was hoping to end up with a string of length (ROWS*COLS)*64/8, because each element is a 64-bit double, and every 8 bits will be interpreted as an ASCII character. Or am I understanding something wrong?
Message 1 of 10
(3,656 Views)
Hi doug,
because you cannot concatenate strings at all using loop tunnels…
Simple fix (using ConcatenateStrings):
Message 2 of 10
(3,635 Views)
this surely has something to do with how memory is allocated.
a string is a consecutive block of memory.
if you want to resize (add to) a string, new memory has to be allocated for the whole resulting string and the old part copied into it.
since this is very inefficient, i presume that labview prevents you from doing that.
use gerd's way to circumvent.
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 3 of 10
(3,617 Views)
Accepted by topic author dougbockILT
(First of all, you don't need the inner loop. You can cast a 1D DBL array directly.)
Second, all you probably need is a flatten to string without size information prepended, right?
Message 4 of 10
(3,609 Views)
My problem is that I want to convert the 2D Array to an ASCII string.
So for the following 2-by-2 array of doubles:
IN DECIMAL
15.458 0.123
5.007 6.540
IN BINARY
0100000000101110111010100111111011111001110110110010001011010001 0011111110111111011111001110110110010001011010000111001010110000
0100000000010100000001110010101100000010000011000100100110111010 0100000000011010001010001111010111000010100011110101110000101001
concatenated column by column, row by row:
0100000000101110111010100111111011111001110110110010001011010001001111111011111101111100111011011001000101101000011100101011000001000000000101000000011100101011000000100000110001001001101110100100000000011010001010001111010111000010100011110101110000101001
interpreted as ASCII string:
@.ê~ùÛ"Ñ?¿|í‘hr°@+ Iº@(õ\)
which has length 32, as expected.
Message 5 of 10
(3,599 Views)
(posting by phone, cannot test).
My code should do that. Have you tried?
If you want to do by columns, transpose the 2D array first.
Message 6 of 10
(3,591 Views)
Works, however I am not getting the same output as expected (done on this website) ... I'll trust LabVIEW on that.
Many thanks!
Message 7 of 10
(3,576 Views)
try right click on the string indicator and choose "Hex Display" perhaps this more helpful to compare.
Message 8 of 10
(3,571 Views)
Hi doug,
that website only accepts ASCII text, but no DBL float numbers…
Message 9 of 10
(3,568 Views)
Thanks Gerd.
I used this website to convert my doubles to binary, followed by this website to convert the concatenated binary to ASCII.
Message 10 of 10
(3,562 Views)
