Why would LabVIEW make many temp files with the vision module under W2K UserProfile/Local Settings/Temp directory ?
Hundreds of temp files have been generated by LV in the temp directory.
Why ?
(2,426 Views)
How are you using the vision module? I thought it might be because you weren't disposing of your images, but when I ran a quick program without disposing of the image, no temp files were created. Is this creating a memory problem for you?
(2,411 Views)
