Why would you create a property node
I have been working with an instrument driver that deals extensively with property nodes. I have never worked with them before and their purpose is a bit unclear to me. What is the programming reasoning behind property nodes and what kind of applications are they useful for?
(2,780 Views)
Right-click on any of the property nodes and select "Help For Property Node."  This is a very important LabVIEW concept.  It allows you to manipulate the properties of a control programattically.  For instance, you could change a control's enabled property to gray it out.
[edit]
Actually, it is called the "disabled" property.  Go figure.  😉
[/edit]
Bill
CLD
(Mid-Level minion.)
(2,776 Views)
I'd have to see the code to see exactly what they are doing with it.  But Property Nodes can do all kinds of fun things.  They set/get the properties of a control/indicator, VI, VISA Session, DAQmx Task, DAQmx Channel, etc.  They are often abused to set the value to a control/indicator, which is not a proper way of using them.  The most common thing I do with property nodes is to disable and gray out a control to keep users from playing with a control when I don't won't them to.
(2,769 Views)
